Layout declare
Layout declare
Layout declare
I need to declare a layout in all the parts of some assemblies.
What is the quickest way to do it? (Some of the parts have another layout declared already)
RE: Layout declare
I think the fastest way to do it is to make a mapkey. It will still require a bit of manual work but if you set up the mapkey right, it can open the parts from the assembly, declare the layout, close the window and reactivate the assembly. Then all you need to to is pick the next part and hit the mapkey again.
