PDM gone from FILE EXPLORER after SP instal
I jumped from SP2.2 to 4.0 & now my VAULT is not showing in my FILE EXPLORER.
Should I stop & restart the VAULT now?
Quote (Jack L Tate):
Right-click. It's friggin' magic!
FAQ376
Windows XP ~ NVIDIA Quatro FX 3450/4000 SDI ~ Microsoft Wireless Optical Mouse 5000 ~ SolidWorks 2007 SP2.2 ~ SpaceBall 5000
www.Tate3d.com
RE: PDM gone from FILE EXPLORER after SP instal
Did you restart/reboot your pc after you upgraded? Was virus protection turned off when you upgraded?
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Is the PDMWorks add-in enabled in SolidWorks Explorer?  Make sure it is added in...
Pete
I have rebooted.
Virus protection was ON during the upgrade. I have been told repetedly that it would not be a problem... by my IT support. But this might be the first time it has been.
I have the VAULT in SolidWorks Explorer... jut not in SolidWorks. Now it is not on the ADD-INs list in SolidWorks. That was the first place I looked.
Excuse me while I walk down the block for a sub.
FAQ376
www.Tate3d.com
Tate,
Is it an admin image or a local install? If it's an admin image, the batch file to install Explorer may not have the variable set correctly or it got messed up somehow.
From what I've heard, SW saying to turn off your virus protection is a CYA thing. I can't turn off my virus protection at work and have never had it cause any issues with installs. The statement came from instances where certain virus protection builds caused problems. Kind of like drug disclaimers: may cause irritability, drowsiness, bladder control problems, etc...
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Sometimes SolidWorks causes irritability (why did my views change during publishing?), drowsiness (someday my large assembly will rotate...zzzz), bladder control problems (I just HAVE to get this back in the vault in case it crashes!), etc.
clown
Remove PDM explorer from you PC then reinstall. We have to do this every upgrade.
Bradley
SolidWorks Premim 2007 x64 SP4.0
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
What's PDM Explorer?
FAQ376
www.Tate3d.com
Tate,
If you're using '07, PDM is a part of SW Explorer...
Jeff Mirisola, CSWP
CAD Administrator
So I should remove & reinstall SOLIDWORKS EXPLORER then?
I'm looking for a program called PDM EXPLORER & not finding it.
FAQ376
www.Tate3d.com
Jeff is right it is called SolidWorks Explorer
Bradley
I'll try that before a clean uninstall & reinstall... which is what I'm now told to do.
FAQ376
www.Tate3d.com
No do not do a clean uninstall & reinstall. On a new machine here, we always have to delete SolidWorks Explorer then reinstall SolidWorks Explorer.
Bradley
That seems to have worked...
Let me see who gets the gold star on this one...
FAQ376
www.Tate3d.com
Thanks for the star TateJ
Bradley
