Running different versions of Invetor
Does anyone know the downside of running Inventor 2008 Pro on the same laptop that has Inventor 10 pro on. Reason being, I contract to companies that use 10 pro and other companies that use 2008 pro, OR.. is there a way of creating parts using 2008 but saving/exporting as 10?
(life would be sooooo sweet if every one upgraded at the same time)!!!
Many thanks in advance
RE: Running different versions of Invetor
You shouldn't have any problems having both versions on your laptop. Unfortunately, no you cannot save to a previous version in IV yet.
Keep in mind though, once you open a part in a newer version and save it you WILL NOT be able to open it in the older version. That is the downside.
