Concrete Slab-On-Grade Control Joint Reinforcement
I have always detailed my control joints for a slab-on-grade with the reinforcement running continuous through the joint. I show a (1/4)*slab thickness cut and the steel mesh or other reinforcement running continuous. Does anyone terminate there reinforcement at the joint? Why?
RE: Concrete Slab-On-Grade Control Joint Reinforcement
http://www.swijetty.com
Sea Water Intake and Jetty Construction
