Purge? Delete? Duplicate entities
A co-worker asked me this question and I am stumped because I rarely use it.  In fact, I don't think I've ever used it.  Years ago there was a command (and the name of it escapes me right now) that would delete/purge duplicate entities/lines (or whatever) on the same layer.  It was used to clean-up drawings and reduce the file size.  Does anyone know what this command might be?
Thank you.
RE: Purge? Delete? Duplicate entities
From the Express Tools:
OVERKILL
Removes unneeded objects by deleting duplicates and combining line and arc segments that overlap.
Command: OVERKILL
Select objects: Use a selection method to select annotation objects
OVERKILL removes objects whose geometry is redundant. For example:
Duplicate copies of objects are deleted
An arc drawn directly over a portion of a circle so that the arc cannot be seen is deleted.
Two lines drawn at the same angle so that they partially overlap are combined to form a single line.
Duplicate line and/or arc segments within polylines are removed.
ADT 2004
Thank you so much for your answer!
