Stone Columns
Stone Columns
Stone Columns
Would appreciate feedback on the optimum gradation of stone column backfill materials. They say around Thanks.
Noah
RE: Stone Columns
As far as optimum gradation, i'm not sure.  But I believe the typical state road ABC stone (or GAB depending on where you are) was what came to the site on a couple of projects I've worked on.  I couldn't open the specification page but these were the guys.
http://www.geopier.com/index.asp?id=31
or just
RE: Stone Columns
A common material used in the Pacific NW is 1-1/4" to 3/4" clear crush. This has also been called a Railway Ballast. It is important that this is a clean material with less than 5-percent passing the #200.
RE: Stone Columns
Work with your local contractor.  They are very good at providing information not only on what is best for them but what materials, locally, are the best.  They are often happy to help by knowing about the job and by having a bit of inside information about the tender.
