Pump Packing Storage
I am in the process reorganizing our warehouse. When i do this i wanted to develop a procedure for pump packing  storage. I need to talk with someone to ensure me that our  storage procedures are correct
RE: Pump Packing Storage
ddurdle
The pump manufacturer should be able to give you long term storage procedures, I would suggest you contact them for input.
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
Do you mean packing a pump away for storage or do you mean storing pump gland packing material?
Where do you use (gland) packing in this day and age in such large quantities that you need to keep a warehouse full of it?
Most packing should come ready protected for long term storage but as already suggested, the supplier will give you full instructions to protect and store their particular product.
If you mean Packings or O-rings.  I would get a copy of MIL-HDBK-695 - Rubber Products, Shelf Storage Life.  It really comes down to what material are the packings made from because some materials need age & heat control during storage.
Here is a link to download the MIL HDBK
http://assist.daps.dla.mil/quicksearch/
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right."  -- George Best
It has been mentioned already, speak to pump manufcturers as if you dont follow this to the book, you could have an impact on any potential warranty claims.
Its important to mention to the manufacturer that long term storage will be requires as they can add surface protector to the pump before despatch, storage is simple, main point is to rotate the shaft c.6 times every few weeks.
Hello again "ddurdle". Can you answer some of the questions asked of you please, so that we can help you better?
It is no use posting a question and then ignoring it! Makes us feel we're wasting our time here!
Thanks Cheddercaveman for beingf so direct asking for a reply - how many time do we respond with out any answer from the OP - it really make you feel you are wasting your time  with some questions.
The OP hasn't checked back since June 24, so it's probable he got the answers he needed.
For completeness sake, I'm posting the single reply to the identical post on another forum.  This post was made by mbensema on June 24:
Quote:
You can find a technical publicaton on the FAG website that has a section covering handling and storage of bearings. www.fag.com  Search for WL-80-100/3 "Mounting and Dismounting of Rolling Bearings"  If that is not enough information, call your regional manager and ask to have a service engineer come out to give you some guidance
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Want to post an image? Look at the FAQ's in forum559: SolidWorks 3D CAD products
