Force Req'd to remove bearing? (press fit)
Anyone have a shortcut to estimate force required to pull press fits apart? We've got a maintenance guy looking for info so they can buy a new puller (I said just get it as big as you can) Bearings are heated for shrink fit.
Thanks!
Thanks!
RE: Force Req'd to remove bearing? (press fit)
information as to the sizes of shaft
or bore. The bearing manufacturer
certainly specified some value or
recommended some specific tool.
Good idea - I'll contact bearing sources and ask.... but the latest group of Tech Support Engineers at most bearing companies just seem to look in the catalog. As soon as the dept Machinist Handbook wanders back home, I can check there too.
OR
2.If the manufacturer and/or local supplier is easily accessible to you right away, get the dets from the horse's mouth straightaway.
a) Heat the brg with local open flame and/or induction coil heaters. Will ease the fit atleast to the extent the puller can pull off with ease - expect ~1.0 to 1.25 times the force
initially utilised to final-seat the brg, had it been a shrink fit on the tolerances.
b)A 3-Jaw std design puller w/ a hyraulic pusher cyliner arrgt capable of 3.0T -5.0T hydr load should work.
c) Personally have also used a simple plate puller sized to seat 'behind'the brg on its seated posn and use hydr force as above toease it out.
d) NO HAMMERING pls- if you do, forget any reuse of the brg.
Jesus is The TRUTH
R.G.Budynas, "Advanced Strength & Applied Stress Analysis" (New York: McGraw-Hill)1977 has a good section on shrink/press fits under Thick-walled cylinders [pg. 143]
