4 offset Butterfly Valves ( Quadruple Eccentric )
I was wondering if anyone can provide me with manufacturers (name, brand and location) of 4 offset Butterfly Valves - Quadruple Eccentric.
I had Literature of an European manufacturer, however i let a colleague borrow it and is lost. I don't remember the name ether.
I also tried searching on Google without success.
Thank you in advance for your help on this.
RE: 4 offset Butterfly Valves ( Quadruple Eccentric )
Zwick a german manufacturer does tripple offset, Bray does double offset I didnt know a quadruple offset existed
Vanessa also makes a triple offset butterfly valve.
http://www.tycoflowcontrol-na.com/ld/RMISB-0018-US.pdf#xml%3Dhttp://www.searchtycoflowcontrol.com/texis.exe/webinator/search/pdfhi.txt?query=triple%20offset
What is the 4th offset? This is also new for me.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
I'm having a hard time imagining how there could be four eccentric motions in a butterfly valve, given the number of moving parts.
I could imagine there being four physical eccentrics, arranged as two pairs, at extremes of the disc and shaft.
Mike Halloran
Pembroke Pines, FL, USA
UNSR60001,
       it is only six years I'm in the valve business, but I've never heard about Quadruple Offset valve design, me too.
       Whatever it is, to me it sounds like a fancy mistake or a marketing invention without much technical meaning...(?)
       In any case, many good discussions have been carried out within this Forum about Triple Offset valve design already. See, for example:
   -       thread408-64692: butterfly valve    about the type of design in general;
   -       thread408-145006: Butterfly valve design: conc, ecc, doubl ecc or triple eccentric?    about advantages and disadvantages;
   -       thread408-135872: The top three sellers for butterfly valve?    about the most important Manufacturers;
   -       thread408-141966: Triple offset butterfly valves    for a trouble-shooting case study;
   -       thread408-149142: Characteristics for triple offset butterfly valve    about the control characteristic;
   -       thread819-149326: Butterfly Sealing Techniques (Metal Seat Type)    about the sealing mechanism.
       To complete what mentioned by Ashereng, correct links for information about Tyco VANESSA are the following:
              http://www.tycovalves-eu.com/brands_results.asp?Selection=Vanessa
              http://www.vanessavalves.it
Hope this helps,           'NGL
