ASME SECTION VIII FLOATS
Are floats internal to a pressure vessel subject to the requirements of ASME SECTION VIII specifically UG-28?
RE: ASME SECTION VIII FLOATS
Short answer, no.
Long answer, the float is not required to be a code component.  It falls under the piping components exception U-1(e).  It would also likely fall under the size exception in U-1(i).
