how do you calculate the cfm of a compressor
How do i determine the cfm rating of a compressor. i want to determine wat size dryer would work best with the compressors i have.
if there are any other ways to determine the proper size dryer for a compressor i would like to know.
Thank you all.
Thank you all.
RE: how do you calculate the cfm of a compressor
The manufactures name plate should spec out how many CFM your compressor can produce. From here you can size the drier accordingly. For example I run two 200hp VSD at 1000cfm each and my drier is rated from 1600 cfm we sized it according to the maximum amount that could ever be put across it at one time. Make sure you consider prefilters and after filters on your drier it will exstend the life of you drier. Our previous compressor and drier lasted 25 plus years and we have just replaced and upsized this past fall. If you are still having problem tell me what size hp your compressor is and I'll work the math and show you as well.
2571
thax again?
2570
