M+P vibration control systems
Are there any experts on the M+P vibration control system in this forum? My question is this: When running a random vibration are the responses to each accel integrated over the entire duration of the run? Or is that only for the control channels? I am confused about this as an issue arose the other day at work and I was asked that question but could not provide a good answer. Thx
RE: M+P vibration control systems
In order to try and help you out further I would like to know if you mean “averaged” instead of “integrated.” If you do, then the answer is that the control channels are averaged over the whole spectrum.
What are the other channel types that you are using?
