Control valve inlet & outlet reducer/expander
Dear Colleagues,
When the required body size of a control valve is lower than the inlet and outlet line sizes, inlet reducer and outlet expander are normally provided. Under what circumstances do we use eccentric reducer/expander? Likewise, under what circumstances do we use concentric reducer/expander? If eccentric type is required, under what circumstances do we use bottom flat orientation (or top flat orientation)? Are there any industry standards? Thanks in advance for your help.
RE: Control valve inlet & outlet reducer/expander
My take on the subject is that mostly it doesn't matter and a concentric reducer is fine. If you have solids present that may settle out, then (I believe) it is best to use an eccentric reducer and to put the flat side down. On the other hand, if you have bubbles in a liquid then putting the flat side up eliminates a potential spot where gas could accumulate. In the overwhelming majority of cases the velocities are adequate to keep the solids and the bubbles moving and flushed out of the system when you use concentric reducers.
In a recent thread (see thread408-190009: Why is there a pressure drop when the control valve was opened?) BigInch gave a link to the Fisher Design Manual. If any reference anywhere has something sensible to say on this subject it will be the Fisher book.
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
To Mr. Katmar - guilty as charged.
Doug.
I admit being one of those that took part in the heated confabulation mentioned by Katmar about reducers on centrifugal pump suction lines.
An old ROT on CV sizing I remember: never less than two sizes below size line and never less than half the pipe size.
The general recommendations, from a process point of view, to avoid adversely altering the CV characteristics and capacity are:
1. Avoid arrangements that can result in a nozzle-effect into the CV
2. Avoid closed-coupled inlet block valves reduced from line size
3. Avoid contorted manifolds to achieve accesibility, in particular in block-and-bypass arrangenments
4. Use straight-line pipe sections into and out of the CV as needed for the CV, as originally established by the control engineer. A ROT for reducers and expanders: 12
nominal pipe diameters (NPD) upstream and 5 downstream. For elbows on the same plane 18 NPD upstream, 30 NPD if not on thesame plane, etc., etc.
These are ideal situations not always achievable. Piping designers, who determine the actual layout, and process-control engineers should cooperate on this subject.
Also if tying into an existing piping system the existing pipe elevations could dictate need for concentric or eccentric.
It appears that there are no "generally accepted" standards, but you apply common senses and do what is logical on a case by case evaluation. Once again, thank you.
