How to model generic gear in Pro-E?
I know this thread was posted several times, but the links to tutorials, etc, are dead by now :( I would like to model a generic gear in Pro-E that can be changed into any size realistic. I have the formulas but I'm struggling transfering my relations, paramters. etc into Pro-E. Any help would be greatly appreciated. Thanks
RE: How to model generic gear in Pro-E?
Here is a documento I download sometime ago
http://www.mooload.com/new/file.php?file=/data/210607/1182462880/Involute+Gears.pdf
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right."  -- George Best
Thanks. I will check it out...
Actually, even though this helps me to create one gear, I am still unable to create a generic gear. I've been playing with this model most of this morning and using formulas, relations, parameters tried to create a generic gear, but still have problems getting it right. I would like the gear to be created based on the Pitch Diameter, # of teeth, and Pressure angle.
Unfortunately, I have been undable to specify the pressure angle, and the model I have created work only for certain Pitch diameters, but if I designate a very small (e.g. 2 in) or a very large (20 in) my relations are not working correctly.
So my question is this: Is it actually possible to design a gear based on the parameters outlined above, or do gears change inhernently to the extent that the formulas used to create the curves etc change? Any help is grealty appreciated
I think there are a couple of generic models of gears over at mcadcentral
Thanks for the hint. I think they might have what I'm looking for. (their website is down today...) Have a great day.
Alright.. Thanks.
In case anybody is interested:
I found another website that has large library of Pro-E models for free...
https://sdp-si.com/eStore/
These models actually come like they are made in Pro-E...  :)
