"E" With Metric Tolerance
I am looking for an explanation of the use of the letter E in a circle following a metric tolerance (h6) on a German drawing
RE: "E" With Metric Tolerance
Revision?
In the Military/Defense world we put this symbol on our drawings to indicate what the changes were on each revision.
Here is an example of a Milspec bolt
http://www.mooload.com/new/file.php?file=/data/210607/1182437217/MS9560G-X+-+Double+Hex+Bolt.pdf
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right."  -- George Best
It does not appear to be a rev
drbauer
Circle(E) in ISO signifies the "Envelope Principle" which suspends the ISO "independency principle" for measurement of size and form and invokes conditions equivalent to the ASME "Taylor Principle, Rule #1" commonly known as "Perfect form @ MMC".
Paul
