Fuse Standards
Fuse Standards
Fuse Standards
Quick question, are there a set of standards out there for low voltage fuses? Is it ANSI, NEMA, IEEE, UL? Or is it just like some sort of understood agreement between companies? Links would be greatly appreciated , even if I have to buy them.
RE: Fuse Standards
ANSI C97.1, ANSI/UL 198 series for various fuse classes.
I'm sure there are more.
RE: Fuse Standards
Most fuses conform to some national or international standard. A look through the major fuse manufacturer's websites will yield a lot of information for no cost.
http://www.bussmann.com and http://www.ferrazshawmut.com are a couple of good starting points.
  Sometimes I only open my mouth to swap feet...
