Checking dimensions for external references within a sketch
Hi, I know how to check for sketch relations which relate to something outside of the sketch they are in, but I can't find a way to check for dimensions that have been measured against something that is outside the sketch.
The reason I want to do this is so that I can re-order my sketches.
I haven't been able to find a way so I've had to delete all the dimensions, re-order the sketches and re-dimension it. Obviously not the most productive way of doing it...
Thanks for your help
RE: Checking dimensions for external references within a sketch
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Edit the sketch and then click on "Display/Delete Relations". In the relations property manager box, at the top chose "external". This will list all the relations and dimensions that are measured to something external to the sketch.
Timelord
I went through all the external relations and none of them would have stopped me from re-ordering the sketches that I wanted to, but when I tried to do that it wouldn't work. Once I deleted all the dimensions then it worked...
I using SW2005 SP5.0 and they show up in my dialog box as distance1, distance2 etc.
Timelord
