Literatures re Cost Optimisation
Anyone can help me  please find some existing literatures aboout Cost Optimisation in general and Portal Frames in particular.
Many thanks
RE: Literatures re Cost Optimisation
Hi marblaze
Following is a rough breakdown of the costs for a 25 metre (82 foot) span, 7 metre (23 foot) eave height, portal frame building, from Waston (1996), Costing of Steelwork from Feasibility Through to Completion, Steel Construction, Vol 30 No 2:
  • supply, 72%
    • steel, 20%
    • purlins, 13%
    • sheeting, 39%
  • fabrication, 15%
  • surface treatment, 2%
  • erection, 11%
    • steel, 2%
    • purlins, 4%
    • sheeting, 5%
Having a structural engineering background, the main tips that I can give you are:
  • keep the structure simple, e.g. standardise bay widths
  • give careful consideration to selection of purlins and sheeting
  • rationalise member sizes
  • maximise shop fabrication and minimise field welding
  • keep the connections simple, e.g. minimise number of connection components; minimise use of stiffeners
  • standardise connection geometry and elements, e.g. one bolt size, grade and tightening procedure; one electrode strength grade, weld category and weld size (if possible)
Also, see the following papers from the Structural Steel Education Council (www.steeltips.org/index.php):
  • Cost Considerations for Steel Moment Frame Connections
  • Value Engineering and Steel Economy
  • What Design Engineers Can Do To Reduce Fabrication Costs
  • Designing for Cost Effective Fabrication
