CUT in ISO exploded view
Anyone know if you can make a cut on a drawing thru a ISOMETRIC exploded view? If so how?  (SW 2007)
RE: CUT in ISO exploded view
You need to make the cut in the assy. Create a config and make the cut.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Thanks Chris, I will try that tomorrow when I get back to work...
Not sure if it works with exploded views but we use the broken out section tool to show hidden detail etc in an iso view.
Woolly
