Display Axis
Display Axis
Display Axis
Hey,
How do you turn on axis lines created in an assembly for a drawing? I'm currently looking at the "View" options in the drawing and can't find where to turn it on.
FYI, "Hide All Types" is not checked
Macduff spin
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 4.0
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
RE: Display Axis
You can make it visible under the Customize option.
Better yet, RMB on a toolbar, select Customize > Options and select the Show all options. This will display all commands in the dropdowns.
cheers
RE: Display Axis
Still doesn't work sir. I'll call my VAR because we have tech support here. He has the capabilities of logging into my computer.
Thanks guys for your help,
Colin
Macduff spin
Colin Fitzpatrick
