Copper pipe soldering limit
What is the largest copper pipe dia. that is commonly soldered? How is 4in. and 6 in. copper lines in domestic and in mechanical systems connected? Flaged, threaded or soldered, or other means?
RE: Copper pipe soldering limit
We still have considerable Cu water piping in the 3" and 4" range that was soldered with tin/lead solder. This upsets the ESH people no end. The lead is non detectable in the water at present so I guess we consumed it years ago.
http://www.silfos.com/
htt
Check this site.
I was involved in a incident investigation regarding the filling of Dewar's at the storage tanks by a lab technician. It was when they modified the local draw off station that I discussed the brazing of the Cu with Sil-Fos.
I'm pretty sure that all pipe in the high side of plant is SS.
If it's a brazed aluminum exchanger inside, this is what it looks like naked, in case you're curious:
http://www.pipingdesign.com/images/exchanger1.jpg
http://www.pipingdesign.com/images/exchanger2.jpg
Paul
