Trefoil Cable Configuration Question
We are building a 34.5 KV collection system for a windfarm, and almost all the 3-phase cable is configured in trefoil.  Occasionally, the installers make a mistake and in the middle of a circuit, one cable will jump through the other two.  For example, you might have 1000' where the orientation is A-B-C as you look at a cross-section of the 3 cables, and then C accidentally passes between A and B and now you have the next 1000' with a cross-section of A-C-B.
Question - Does this create a problem?  EG. - Will the current-carrying capability of these cables be diminished?
FEinTX
RE: Trefoil Cable Configuration Question
It's probably a good thing.  Helps balance out any asymmetry in the mutual inductance.
