inserting a drawing view at origin
I am trying to place a drawing view at the origin of the drawing sheet so that the lower left corner of the part is EXACTLY on the lower left corner of the format. I need to do this for a sheetmetal part to be DXF'ed out to our plant for manufacturing. Is there a coordinate system on the format to align to some how?
Thanks in advance
KTG
Thanks in advance
KTG
RE: inserting a drawing view at origin
Create a csys in the part at the lower left of the flat pattern.
Select the view, right click and select properties.
Go to the origin section and change to on item.
Pick the csys you created. Change the View location in sheet x and y values to zero.
Peter Stockhausen
Pollak Switching Products
Thanks, thats what I thought but when I try to create the coor. sys. in the unbent part it always rebends itself. So the coor. sys is in the wrong spot. What am I missing?
Peter Stockhausen
Thanks again, I tried your idea and still have the same issue. Nomatter what I have tried, everytime I try to create the csys the part automaticly rebends. I have tried creating the csys in the generic, and in the instances them selves with no luck.
I have a part programmed to 4 different sizes.
So my family table has column for the paramter for the size and a column for the unbend feature.
see below:
Pro/E Family Table
SIDE_JACKET
INST NAME MODEL_SIZE "F3044 [UNBEND]"
!GENERIC 8_TUBE N
JACKET_4_030 2_TUBE N
JACKET_4_030_FLAT 2_TUBE Y
JACKET_4_060 4_TUBE N
JACKET_4_060_FLAT 4_TUBE Y
JACKET_4_090 6_TUBE N
JACKET_4_090_FLAT 6_TUBE Y
JACKET_4_120 8_TUBE N
JACKET_4_120_FLAT 8_TUBE Y
I'm sure it's me missing something but I can't get it.
I'm running Wildfire 3.0 M060 on both 32 and 64 bit computers. same results on both systems
Peter Stockhausen
We had this as a set of mapkeys, since our laser guys were doing it about 20-30 times a day.
Ben Loosli
Sr IS Technologist
L-3 Communications
