Condensate storage tank material suggestions
I posted this earlier in the mechanical engineering forum for boilers and pressure vessels. I thought perhaps it might be more suitable here.
Looking for condensate storage tank material suggestions. (carbon steel, lined carbon steel, duplex stainless, fiberglass, etc.) We are looking to purchase (2) several thousand gallon tanks to act as storage/surge tanks for condensate coming back from many buildings connected to our steam distribution system.
We currently have (2) storage tanks from the early 50's that have served us well, that were originally used as lime softening water tanks, I am not sure when they were switched over. These current tanks are fabricated out of carbon steel.
I would be very hesitant to use 304 or 316 SS due to the possibility of SCC, even though our chloride levels are normally low (6.4), there is a possiblilty they could spike if we had problems with water heaters in buildings on our steam distribution system if the water heaters had tube failures and sent raw water into our condensate return stream. A duplex stainless steel could be a possibility.
Below are our condensate conditions:
Chlorides: 6.4 mg/L
Conductivity: 2.8 uS (can be up to 70 temporarily if we have a large water heater failure on steam distribution system)
pH: 7.5-8.5
Temperature: 150-180 degF
hardness: 3-4
Thank you, -Tim
Chlorides: 6.4 mg/L
pH: 7.5-8.5
hardness: 3-4
Thank you, -Tim
RE: Condensate storage tank material suggestions
My hunch is that composite tanks would be better. Less cost and good durability. Someone else will need to recommend a resin system for long term hot water exposure, but it is done all of the time.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Strider
http://www.corrosionist.com
