Rendering to a white backround viewport
I'm currently using AutoCad 2008. My problem is that when I try to render a 3d image to the viewport I can't seem to figure out how to get the backround white. It always comes out black. I've tried everything I can think of, I've been into the options and changed all the 3d/display/color settings I think might apply. The help feature is a joke regarding this matter. I've been thru the advanced rendering settings and can't figure it out either there. I had to resort to making the last image a bitmap, importing it into MS Paint, set fill with white, then importing the image back into autocad for the sole purpose of having a title block. This worked out fine except for the fact that I had a big black box around the image and it was difficult to size very well. I know if I could figure out how to render it to a white backround it would look better and I could get it bigger in the viewport. So does anyone have a clue what setting I could be missing? This would help me greatly when I have to do my next isometric drawing.
RE: Rendering to a white backround viewport
View -> Render -> Render environment
I just turned the fog on, and set it to white, with 100% far, and 0% near, with near and far distances set to miss the object.
Older versions you could just tell it to use a different color background, and specify what it was. Haven't found that in 2007 yet, if it still exists.
