USE OF AISI4140 UNDER ASME VIII
Is AISI4140 or AISI4340 acceptable for use and a pressure containing part (such as flange or cap) under ASME VIII or is it restricted to bolting (per it's equivalent ASTM A193 B7)?
I am looking at a filter vessel that was assembled using API standard oilwell type componentents machined from AISI4140.  Where it is being used it should ideally be treated as a vessel and the design should be checked accordingly.
Any assistance is appreciated.
CSGWB
RE: USE OF AISI4140 UNDER ASME VIII
Please see the applicable tables in Section VIII-1 for the permitted material specification.  i.e. UCS-23, UHA-23 etc.
If the material is not listed in the table then it is not a premitted material for construction to the code.
Hope you do not plan to weld it.
See UCS-5(c) and table UCS-23
Thank you eliebl and deanc
That was my undrestanding also.
No - welding was not occuring on the item.  All joints are threaded (buttress) which I believe leads to other issues anyway particularly on a 10" shell.
CSGWB
