Stabilizing Block Foundation Walls
Does anyone have experience with any of the products in these websites for reinforcing block walls?
http://www.thereinforcer.com/
http://www.fortressstabilization.com/index.php
RE: Stabilizing Block Foundation Walls
It does not address the real problem, which is excessive soil pressures due to poor soil, excessive moisture or both. If the conditions causing the distortion are not corrected or improved, you can expect greater forces.
It must be engineered and not just applied by a contractor according to a "one size fits all" method.
Dick
