Receptacles on Cable Tray
A client has several labs with duplex receptacles mounted on cable tray (all below the ceiling). Equipment on benches, tables or floor is plugged into the receptacles. They would like a similar approach for a new lab. I thought the installation of receptacles at this height for equipment mounted this low was against code (this would be a first time application for me). Am I wrong? Before I bring this up...would appreciate confirmation and applicable code citations.
I'm having trouble finding applicable codes...only citation I could find...
NEC 400-10 (pull at joints and terminals)
Thoughts/comments would be appreciated.
RE: Receptacles on Cable Tray
Any chance they are using metal (or non-metallic) raceway?
Most raceway manufacturers have receptacles that mount in these raceways for the exact application you are describing.
