5 Volt Regulator Card
What would be the significance of testing a 5 Volt Regulator Card by taking the difference of two current measurements. One measurement at 15V and the other at 14V.
The voltage regulator is used to drive LS32 and LS13 Line Drivers and Receivers.
[url=ht tp://img14 6.imagesha ck.us/my.p hp?image=t ifpowersup plyxh0.jpg][/url]
[url=ht
RE: 5 Volt Regulator Card
2 current measurements?
at 2 different voltages?
Four variables?
Can you be more precise?
Keith Cress
Are they looking for the same input current under both Vin conditions? Or constant power so that when V goes up, I goes down?
It sounds like it might be a test spec to weed out design using linear regulators. In other words, a procurement qualification test vice production testing.
Maybe...
TTFN
The 5V regulator card is used in a Tempest Isolation Filter (TIF). The TIF is installed on the interface lines to prevent inadvertent transmission of classified data. It receives 5 and 15 VDC operating power from another unit a Waveform Converter.
For a checkout procedure in a Technical Order T.O. it calls out to test regulator card by using two power supplies.
Set PS1 to 14 VDC and PS2 to 5.1 VDC.
Measure current on PS1 14 VDC.
Turn Off PS1 & PS2 and adjust PS1 to 15 VDC.
Turn On PS1 & PS2.
Measure current on PS1 15 VDC.
Calculate the difference of current measured from I(15VDC) - I(14VDC).
The T.O. states it should be between 75 to 125mA, but it was changed from 0 to 60mA difference with no explanation.
We have tested 19 TIFs with a low reading of 52mA and a hight reading of 110mA.
The question is this test providing useful criteria to pass or fail the TIF?
I am thinking as long as the 5V regulator card is providing the 5V output it is good.
I don't understand the usefulness of this test.
Any comments are much appreciated.
So, my guess is that a higher current may indicate a malfunction or defective components on the board.
TTFN
bowen44; That test as stated doesn't make much sense to me either.
Keith Cress
Moreover, the schematic shows that R6 is selected during test, so what is the test criteria that allows you to select the value of R6? Without that rather trivial piece of data, you can't even tell what the trip point of the shunt regulator is set for. Is the load exactly a 1-A load? or a resistive load? These are all critical design parameters that determine how the designer intended the circuit to behave.
We can make semi-educated guesses, hence, it's a speculative question.
TTFN
A keyword is Tempest. There is a requirement to maintain huge isolation from the red (secret data) side to the black (outside world) side. That's why the circuit is so unusual. The constant current section is designed to, well, maintain a constant current in spite of any data current fluctuations on the red side.
As to the test itself? Hmmmm... Even 60mA is a fair chunk of 1 amp, so I don't understand the purpose of that particular test step either. The isolation and other key performance characteristics could be measured more-or-less directly.
