TORQUE QUESTION
TORQUE QUESTION
TORQUE QUESTION
Hi Everyone,
Would like a little help please.
Have a pc. of 1/2-13 lubed all-thread running thru the middle of a compression spring. As I drive this screw it will bring a threaded block up the screw and compress the spring. When compressed the spring force is 75lbs. Travel will be 6 inches per min. or 78 r.p.m. on the screw. I'm coming up with 3in/lbs req'd. For some reason doesn't look right to me. Driving the screw with a 1.25 p.d. gear. Thanks to all who respond, you have a wonderful forum.
RE: TORQUE QUESTION
http://www.holo-krome.com/pdf/techbk30-33.pdf
1/2-13 = unrc (coarse)
1800 lb-inch gets about 15760 lb clamp force, so 75 lbs would require 75/15760 of 1800, or about 8.6 lb-in, depending on assumptions of lubrication, etc.
RE: TORQUE QUESTION
Does the spring start uncompressed, and is then compressed up to 75 lbf in 6 inches?
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
RE: TORQUE QUESTION
Hi Tmoose,
Not sure this is the figure I'm looking for since my threaded block is not coming up against a stop after which the tension would be induced.
Hi Greg,
The 75lbs. is after the spring is compressed. It will start at about 16lbs. and finish at 75lbs.
RE: TORQUE QUESTION
not sure what you are asking?
is it the torque to compress the spring to the 75 pound force?  this would just be a normal bolt torque calc with the very low clamping force.the torque as the spring begins to compress will be lower than final torq-ue at full compression.
or are you looking for the "power" (torque-time) to run the nut the 6".
RE: TORQUE QUESTION
Lube or not, friction is present and will increase linearly with spring compression.
RE: TORQUE QUESTION
I'm assuming that you want to know the minimum torque required for the screw to compress the spring.  The maximum load would be at full compression, or 75#.
The no-friction formula for axially-loaded screw torque is
T = F*p / 2*pi
where F is the load and p is the pitch or lead of the screw.  In your case the lead is 1/13 = .077" and the load is 75 lbs, which gives you
T = 75 * .077 / 6.28 = .92 lb-in
which isn't much.
You can waste a lot of time getting technical with friction figures, but you can also just triple this figure and still get less than 3 lb-in of torque.
In my experience (21 years) of sizing motors for odd applications, my advice would be: "oversize, oversize, oversize".  The increase in cost is minuscule in comparison to undersizing and having to replace everything and start over.
Don
Kansas City
