Unable to show cosmetic thread on assembly drawing
I am unable to show (import items) cosmetic thread of a part in assembly drawing when it is used more than once. The assembly drawing can only show the cosmetic thread of the very first instance of the part. It does not show the cosmetic thread of the same part on any additional instances.
Did you guy see the same problem?
Alex
Alex
RE: Unable to show cosmetic thread on assembly drawing
SW2007 sp1.1
Alex
mncad
Thanks for your reply!
I followed your method, but my assembly drawing still only shows cosmetic thread on the first intance of the part, not on any other intances of the part.
By the way, I do not see "Marked for draing" option under Dimensions box.
Thanks again!
Alex
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
That explains my issue with cosmetic thread in assembly drawing. I am not sure if I can update SW to sp4 as all seats in my company will have to update. But it is good to know that it is a known issue.
By the way, is there such a thing as "Low Quality cosmetic thread" since you mentioned "High Quality cosmetic thread"?
Is there a way to work around in sp1.1?
Alex
There is no "Mark for drawing" option for Cosmetic thread in the part with my SW2007 sp1.1?
Alex
