CATIA TO PRO-E IMPORT
I'm trying to open several catia files in Pro-E. I have it them in both .igs and .stp formatts.
I've only been able to open one file. With the rest of them my screen freezes up and the applications show "not responding". Is there a trick to opening thes files??
Any of your experience would be helpful. Thanks all.
RE: CATIA TO PRO-E IMPORT
2. How large are the files?
3. What version of Pro/ENGINEER are you using?
It should just be a case of changing the file type to *.stp or *.igs and then opening the file.
Can you open the file with another program or ask someone else to open them for you?
I have had several engine assemblies that I could not open, I gave them to another designer with the same spec machine and same release of WF2 and he opened them with no problems at all.
Good luck
Adrian
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
62 Mb files
Catia version unknown
The definition of stupidity is re-trying the same process and expecting different results (except when dealing with dumb or neutral CAD data). The same process you used on one file will not necessarily work for all neutral files.
Good Luck
Bart
CAD Data Specialist
www.translationtech.com
