2 UNIFORM LOADs??
2 UNIFORM LOADs??
I have a beam and i want to assighn two uniform loads,The first is for all the length of the beam but the second is only
for a part of the beam(in the middle of the beam)Is there an easy way????
RE: 2 UNIFORM LOADs??
For example, if you have a beam with 1 klf load over the entire length, and an additional 0.5 klf over the middle third. Divide the beam into 3. Select line -> Edit -> divide. Once the beams are
divided you can choose to superimpose and you will end up with 1 klf each on the 1st and 3rd thirds and 1.5 klf over the middle third.
HTH
Anantha
