Exporting and importing geometry
I'd like to export the deformed geometry at the end of an analyses in order to use it in the beginning of another one. In fact, i'd like to mesh my part on the deformed geometry to run another simulation. I've succeeding in importing part and field but it's not sufficient for my goal.
Best regards,
Best regards,
RE: Exporting and importing geometry
Have you tried using the command 'PartFromOdb'? This should give you the orphaned mesh part with the deformed geometry. From your e-mail it is not clear what was the exact problem you faced.
Gurmeet
