Change Classifications
Can someone please explain Class 1 and 2 changes for drawings?
Thanks!
Thanks!
RE: Change Classifications
Items in this category will not physically or functionally meet product specifications as a direct replacement item for all applicable applications using the previous revision. Items in this category require new part numbers to be assigned.
Class II (Interchangeable Change)-
Items in this category retain the physical and functional product specifications to act as direct replacement items for all applicable applications using the previous revision.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
One thing that occasionally gets missed on Class 1 is that the changes must be both forward and backward compatible. i.e. not only must the new rev replace the old but if necessary the old rev can replace the new.
