Annoyed by "un-saved document notification" on 2007?
In SW 2007, the "Un-saved document notification" message can be annoying and it can interrupt other SolidWorks activities. Also,Solidworks help doesn't describe any method for changing its settings or turning if off. If you find it is annoying you, then go to Tools pulldown>Options>System Options tab>Backup/Recover. Then look in the Save notification area. Uncheck to remove reminders, or change the settings to increase the reminder intervals. I hope someone finds this helpful.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
RE: Annoyed by "un-saved document notification" on 2007?
Your tip helped me.
I never used the reminder anyway. So, your reminder to turn it off helped me remember to turn if off. A star for you.
Thanks.
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
I can't find it at the moment, but I believe there are also options to change the transparency of the reminder (to make it less obtrusive) and its viewing duration.
