NX4: ERROR: ...not in relevant class.
Hello all,
Working with assembly files, when I save this error appears:
The following parts failed to save causing the overall save operation to fail:
While saving "file name":
"file name"- Internal error: an attempt was made to access an attribute not in the relevant class.
At first I thought it was because some of the parts in the assembly belong to other people, but then I saw the same error with an assembly file containing only 2 components: both mine.
With both components closed, the top file would save. But, with either one or both of the components loaded, the error appeared. Bear in mind, this is an intermittent error. Although it occurs frequently, it is unpredictable.
Does anyone else get this?
'ziner
Peace Through Superior Fire-Power!
'ziner
RE: NX4: ERROR: ...not in relevant class.
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
http://www.siemens.com/ugs
John R. Baker, P.E.
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
-Derek
John R. Baker, P.E.
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
