P&ID symbol for concentric pipes.
I am designing some components to develop a core-annular flow within a circulating system to study multi-phase flow.  I was wondering what the P&ID symbol for a smaller pipe within a larger pipe would be.  The larger pipe is 12 inches, and the smaller pipe would be either 6 or 8 inches.
I.A.A.
RE: P&ID symbol for concentric pipes.
I have seen depictions for jacketed pipe.  Even if you find something graphical, consider a note that describes the requirements.
I have not seen that on a P&ID.
Having said that, nothing prevents you from coming up with a new symbology/depiction for such an arrangement.
Sorry can't be of much help.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Probably you'd need two P&IDs with a large note indicating that one must be read in conjunction with the other. The only similar thing I've had experience with is a shrouded tuyere, but that wasn't a whole piping system.
Wow, I just found it, neat:
http://patents1.ic.gc.ca/details?patent_number=2150455
Paul
I think that I will come up with my own symbols and notation.  When I figure them out, I will post them.  Thanks for all your help.
IAA
