low flow rate centrifugal pump
i am looking for manufacturer who produce centrifugal pump at 3 gpm which can be used as dosing pump how ever i can not use metering from Milton roy pumps as system is pulsation sensitive. is any body aware of any manufacturer who produces low flow rate centrifugal pumps?
RE: low flow rate centrifugal pump
If you're looking for an ANSI design pump, pretty much all of the big names have a similar design.
visit www.cdrpumps.co.uk for a look !!
Centrifugal pump should be always the first shot, but
no always can meet any rated point.
To understand your application, send all important information you omitted.
