ACI 350-06 Required by IBC 06?
IBC 06 specifies several ACI reference standards, however, ACI 350 is not one of them. Since there was a new edition of ACI 350 released at the beginning of this year I was wondering if I need to be using this edition or the older ACI 350-01 since that is what was in effect when the IBC 06 code was written and adopted? What do you think?
I appreciate your feedback.
RE: ACI 350-06 Required by IBC 06?
Even the title of IBC would suggest ACI 350 is not a referenced standard.
If you check IBC Chapter 35, it lists four ACI referenced standards and ACI 350 is not one of them. However, the MSJC Code and Specs (ACI 530) is included. Perhaps, this is what you had in mind.
P.S. I do mean ACI 350 and not 530.
