Internal Column - 2 Bay Portal
Im looking at a 2 Bay portal span about 30m double bay (ie 60m overall bay). Can the internal column (each frame) be designed to take moment or as a prop to the frame.
Any Thought?
Any Thought?
RE: Internal Column - 2 Bay Portal
DaveAtkins
The contibution of the middle column is proportionate to its stiffness. If you can only get an 8" column in the middle and they are 30" on the outside then there is very little point in making them fixed.
Usually the client wants the flexibility of smaller columns in the center.
csd
DaveAtkins
