Stainless steel bolts cut resistance
Hello people!
Can somebody help-me to find a comparsion table with "cut" resistance between steel and stainless steel bolts?
I´m studing a fix solution and would like to check these information to take the right decision,
Thanks in advance
RE: Stainless steel bolts cut resistance
I believe you mean "shear" instead of "cut".  The ultimate shear strength can be estimated from the ultimate tensile strength by using the following relation: ? ~ 0.6 · ?UTS.  Most stainless steel bolts are relatively low strength, but some companies like Bufab Stainless offer high strength stainless steel bolts.  Use the following links for more information:
http://www.bossard.com/techinfo/en/extdoc/TT_04-04.pdf
http://www.bossard.com/techinfo/en/extdoc/TT_18-18.pdf
http://www.bufab-stainless.se/eng/teknisk_4.htm
The greek characters did not appear correctly in my previous post.  Ultimate shear strength is ~ 0.6*UTS where UTS is ultimate tensile strength.
