Steam jet vacuum chiller design
Hello everybody
I am trying to calculate how much water I can chill from 20 to 10ºC (12 mbar-9 torr) using about 50 ton/h steam with an ejector system in a vacuum chiller.
The corresponding flash vapour in the drum is about 1.5% of water inlet flow. Is this vapour constantly removed through the ejector suction? Is the suction load the entire flash vapour quantity?
I think a two-stage intercondensing ejector system would work, but I need help calculating the required steam consumption. Given the suction load (flashed vap?) how do I calculate motive steam flow?
RE: Steam jet vacuum chiller design
Go go www.graham-mfg.com and find a software called Vacworks and order one from the site. That will perform the calculations for you.
rmw
