measuring Pore Pressure In ROCK
How to measure pore pressure within a rock stratum. If you put you standpipe, it will not give you anything unless its tip coincides with an open joint.
RE: measuring Pore Pressure In ROCK
First you have to define rock.  If you are talking about sold unweathered rock, I'd agree.  If you talking about sandstone, I would not agree - other than to agree that the primary permeability and the secondary permeability will be different.
f-d
¡papá gordo ain’t no madre flaca!
