Shop mono rail
Shop mono rail
Shop mono rail
I can understand the aprehension to answer this question so if someone could point me in the direction to figure this out I will do that also.
I want to put a mono rail in my shop. However I want the mono rail to also be able to travel left and right. So in essence I would have two rails plus the mono rail.
The shop is 20x20. What size beams would I need to be able to support at a max 5000 lbs. This is actually over doing it but there may be a once in a life time to use it for 5000 lbs.
RE: Shop mono rail
You need to contact a local engineer that can help.  This would involve checking connection and support points and supporting structure as well as just figuring beam size.
RE: Shop mono rail
I would suggest that you purchase a free standing jib crane. Just tell the manufacturer what capacity, height and boom length that you want. You would need to hire a local engineer to design a foundation as they are subject to a great deal of overturning force.
Another option might be to purchase a mobile monorail crane on wheels (the kind that are sometimes used to lift engines from cars). I don't know what capacities they come in but you should be able to find out.
These should suffice for a small shop.
Good Luck!
