INDUCTIVE KICK BACK
INDUCTIVE KICK BACK
How does one design an RC snubber circuit for a 120VAC solenoid valve so I do not fry some switch contacts when I de-energized the coil? Would I need to get the inductance from the manufactory or can I specify a MOV and how?
RE: INDUCTIVE KICK BACK
http://www
At 120V AC any half-decent relay should be able to switch a solenoid coil without excessive contact damage. Why do you anticipate a problem?
Sometimes I only open my mouth to swap feet...
They only work for so many cycles. They waste less energy than snubbers. If your coil changes states a couple of thousand times a year MOVs are the ticket. If your relays shift a hundred times a day... You need a snubber.
What's the score?
Keith Cress
