SW05: Can't Copy Sweep Feature?
For those still lucky enough to be on SW05, have you ever tried to copy a Sweep feature to another face?  It's not working for me.  Looking for tips.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
RE: SW05: Can't Copy Sweep Feature?
I will have access to SW05 this Sunday. Can you be more specific or  maybe post an image to show what you are trying to do?
DO you mean copying the Helix starting-circle-sketch?
cheers
Well I can move a sweep in SW07 but I can't copy one. So I doubt it can be copied in SW05. You should be able to copy the individual sketches though.
cheers
Yup, that's what I had to do, copy the sketch and rotate it.  This was for a steel cable that I had drawn with a 3D Sketch, and it needed eyelets/loops at both ends.
In SW2007, if you make the cable and loops as multi-bodies, you are able to mirror or pattern the loop body and then use the mates function in the Move/Copy Bodies tool to position it.
Another reason for your company to upgrade? wink
cheers
... or you could create an end loop as a Library Feature and just drop it onto the end(s) of the cable.
cheers
