JOG on leader Dimensions (Solidworks 2007)
I am trying to add a jog on a leader of a regular dimension (non-ordinate).
I thought on the earlier versions on Solidworks you could do it. When leader run so CLOSE to together, I looked at moving the dimension to another view, but in this case I am limited.
Any help?
Any help?
RE: JOG on leader Dimensions (Solidworks 2007)
Hope this helps.
Steven Danasko
Certified SolidWorks Professional
SolidWorks 2007 - SP2.2
UG NX3
Pro/Engineer Wildfire 2.0
The note way, can you have a note with leaders on both sides?
You can have a leader on both sides, but SolidWorks seems to determine if the leader is on one side or both. You can add a second leader and drag the note around to a position where a leader is on both sides.
Hope this helps.
Steven Danasko
UG NX3
Apprecate the help
Jason
SolidWorks 2007 SP4.0 on WinXP SP2
