Drag Coefficient
Drag Coefficient
Does anyone know what the drag coefficient is for an aluminum flag pole? I am trying to do an analysis with a 90 mph wind speed.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Drag Coefficient
If you have access to "EIA/TIA-222-F or G" Standard, there are tables for drag coeff. for round and octagonal monopoles.
In Canada, S37-01 is followed instead of EIA/TIA standard and also has the same tables.
In NBCC-95 Commentary Fig. B-18 can be used to get the wind pressure without going thru calculation of drag coeff.
Hope this helps.
Lokstr
It is in Section 3.8.6 in the 2001 AASHTO code for signs, luminaires, and something else. They give equations for different shapes, but I didn't see anything about materials. I don't think it will matter, though.
Cfig = 0.05 + 0.7 * [mf / (ρair*c)] * (Aref / c2)-1.25
where
Cfig = aerodynamic shape factor (dimensionless)
mf = unit mass of flag (kilograms per square metre)
ρair = density of air (1.2 kilograms per cubic metre)
c = height of flag (metres)
lf = length of flag (metres)
Aref = area of flag (square metres)
for a rectangular flag, Aref = c * lf
for a pennant flag, Aref = 0.5 * c * lf
The design wind pressure is then:
p = 0.5 * ρair * Vdes2 * Cfig
where:
p = design wind pressure (pascals, 1 Pa ≅ 0.02 psf)
Vdes = design wind speed (metres per second)
https://www.naamm.org/items.aspx
It's $25 and you also get another manual. You will need to know the size of the flag and what's it is made of.
