Water treatment for condensing boilers in retrofit
I'm told that the the new generation of low temperature condensing hot water boilers (aluminum or stainless steel heat exchangers) are more sensitive to water quality than traditional copper or steel boilers.
My particular interest is in retrofit situations where the existing piping is full of scale and sludge.  Are there any guidelines for water chemistry that will protect the new boilers as well as the existing (old) black pipe?  Are North American water treatment companies and/or contractors generally up to speed on this?  Are there any high risk points?  In a related topic, should I think about dielectric couplings on the pipe connections?
Mike Thomas
www.efficiencyengineering.com
RE: Water treatment for condensing boilers in retrofit
Check with your local Miura boiler rep... those boilers are small and thus super sensitive to water quality.  They will be able to give you a run down on equipment & upgrading for a retrofit.  With Miura you'll be pleased with how small they are.
www.vanderweil.com
Thanks for the tip MarauderX.  I'm actually thinking about hot water (not steam) systems.  Also I believe the Miura is a steel boiler, rather than the aluminum or SS that I'm looking at.
Mike Thomas
